Cast iron 16 hp Briggs
Rick
12-15-2000 16:45:17
If I run this motor on the points and battery it runs like it has a hot cam. Adjusting the carb does very little. If I run on electronic ignition it runs O.K. Does anyone have any ideas what is wrong here. It's on a Wheelhorse and is a strong motor when I can get it to run. The adjusting screws for the electronic ignition are about to shoot craps so I would like to run it on battery if I could.
venda2
12-16-2000 04:38:22
 Re: Cast iron 16 hp Briggs in reply to Rick, 12-15-2000 16:45:17
If this engine has external points check for corosion between the points and the engine block. I had some corosion that you can't see until you remove the whole assembly. After a good cleaning mine ran fine again. Good luck.
stick
12-15-2000 18:59:26
If adjusting the carb mix has no effect. That is usually a sign of air leak. Spray some carb cleaner or ether around the carb/intake manifold etc. If the engine changes noticable, then air leak.
Rick
12-15-2000 19:59:31
 Re: Re: Cast iron 16 hp Briggs in reply to stick, 12-15-2000 18:59:26
I don't think it's an air leak. It runs O.K. on the electronic ignition. I've also ground the valves and put in a new guide.
Larry Franzen
12-15-2000 20:15:37
 Re: Re: Re: Cast iron 16 hp Briggs in reply to Rick, 12-15-2000 19:59:31
My guess is the coil. I worked on a kohler several years ago that ran poorly. The book said to use only a kohler coil. The book was right. Automotive coils would not work.
Rick
12-16-2000 08:09:19
 Re: Re: Re: Re: Cast iron 16 hp Briggs in reply to Larry Franzen, 12-15-2000 20:15:37
Thanks everybody. I think Larry might have it. I should have told you all these parts are new and I did put an automotive coil on it. This is on a pulling tractor so you know it is imperative that I get it fixed. Do you know what the difference is in these coils?
Robert
12-23-2000 21:12:02
 Re: Re: Re: Re: Re: Cast iron 16 hp Briggs in reply to Rick, 12-16-2000 08:09:19
I have a cast Iron Briggs on an old Gilson, it runs well on a car coil but the points are very critical. clean an adjust carefully.
