Cub Cadet Hydrastatic 125 Transmission
Steve
12-31-2000 16:06:26
My Cub will not go forward or reverse until it has been running for a while ..... .. whats up??
Steve
01-01-2001 17:17:33
 Re: Cub Cadet Hydrastatic 125 Transmission in reply to Steve, 12-31-2000 16:06:26
If it is a hydroststic cub cadet like mine, when I bought it used, it did the same. I changed the fluid by taking off the back plate and changed the hldralic filter. After that it worked fine. Hope this might help. I would try the filter change first because when the fluid is cold it is thick and doesn't move through the filter as fast as when the fluid is warmed up and thin.
