2001 3rd Annual Wheel Horse Show
William Pearson
01-01-2001 08:51:15
The 2001 3rd Annual Wheel Horse Show will held June 1-2 , 2001 at the South Moutnian Fairgrounds in Arendtsville , Pa. 17303 (which is near Gettysburg , Pa.). There will be a tractor pull sled , flea market/swapp meet area , indoor and outdoor show area , on site camping facilities with restrooms and showers also hotels near by and fun for the whole family ! We will have show "T" shirts for sale and dash plaque for exhibitors . Last years show there was 150 Wheel Horse tractors from all over the United States and Cananda , this years show will be bigger !
If you are interested in a show flier please e-mail me yor home address . Bill in Richmond ,Va.
Paul
03-09-2002 06:22:29
 Re: Where to find: cheap John Deere mower seat? in reply to Brendan OMara, 03-08-2002 20:10:17
I have recently searched for a newer seat for my JD 160. The quality of other brand replacement seats don't match the original John Deere. You might get lucky if you advertise or find one at auction. Good Luck
dvogtvpe
03-07-2002 00:17:11
 Re: CubCadet 1000 motor mounts in reply to Peter Bertini, 03-06-2002 14:51:55
you'll notice some vibration but not enough to make you not like it. they rubber mounted them to make them smother & quieter. all the previous years they were just solid mounted with noe rubber mounts . it won't be worse than your 71
your 1000 is the first attempt IH cub cadet made to make a quiet , smooth tractor, the rubber mounted the engine , put side panels on it , made the big exhoust box on the front for cooling all efforts to make them more freindly to consumers
Kent
02-08-2002 14:43:30
 Re: adding hyd valve to jd 300 in reply to Al, 02-08-2002 08:46:05
Hi Al. I'm pretty sure it is an open center system. I would guess that you would just tap into the supply & return lines that go to the factory lift valve, as that would give you constant hydraulic oil flow. Anyway, I hope this helps.
Thomas R. TROIKE
04-04-2001 06:49:29
 Re: 2001 3rd Annual Wheel Horse Show in reply to William Pearson , 01-01-2001 08:51:15
Please send information on WheelHorse Show
Thomas R. TROIKE
971 Princeton Ave
Amherst, Ohio 44001-1139
Thank you!
Kenneth Rita Ward
01-10-2001 14:55:03
please send information on show i am looking to buy D-200 parts and implementsMy address is as follows 1660 S 1000 E Marion, Indiana 46953
will want to attend the show
