Cub Cadet 1715 Trans axle repair
Curtis Morin
01-23-1999 12:07:11
Can Any one tell me if they worked on this part and how dficult wasit and wiht how much sucsess How much was a repair manul?
Curtis Morin
02-02-1999 13:21:53
 Re: Cub Cadet 1715 Trans axle repair in reply to Curtis Morin, 01-23-1999 12:07:11
Looking for Cadet Man
CADET MAN
01-28-1999 15:51:26
CAN BE FIXED AND ALL PARTS ARE AVAILIBLE,GIVE SYMTOMS & PROBLEMS
CADET MAN
01-28-1999 15:44:31
TRANS CAN BE REPAIRED & YOU CAN GET ALL PARTS BUT FIND THE PROBLEM OR SYMTOM BEFORE I SAY MORE
Curtis Morin
01-30-1999 19:06:39
 Re: Re: Cub Cadet 1715 Trans axle repair in reply to CADET MAN, 01-28-1999 15:44:31
Cadet Man It acts like a loose chian with slack in it,it makes a howl noise in any gear.As long as there is a load on it the tractor will run smooth.The engine runs great Thanks for writing me back and is this enough info to help you.
CADET MAN
02-02-1999 16:10:05
 Re: Re: Re: Cub Cadet 1715 Trans axle repair in reply to Curtis Morin, 01-30-1999 19:06:39
Ive seen this problem alot,In the trans is a two keyway shaft,On this shaft is two keys,the end of the key is D shaped.What normally happens is these keys round off just a little bit and then the trans feels like it is jumping in and out of gear and sounds like it is.An easy fix is put 2 new keys in trans.A good fix is put a 4 keyway shaft in with 4 keys.Everything assembles same way.But first check for broken gears or housings before just replacing this shaft.When these keys go bad they can really mess up the trans.good luck let me know how you made out ....later on
