Club Car golf cart starter generator HELP!
Steve
01-11-2001 16:41:03
I still have questions about the golf cart. I did like i was told and the starter generator is putting out 16 volts. I got aggrivated because someone messed up the wiring and I wired up now just like a cub cadet, with the starter switch and all the other things taken loose(example like having to push the accelator to crank it) It cranks by the key and cuts off by the key but I have trouble knowing where the wires run to and from the voltage regulator! There are 3. Which one should run to the battery or starter selonoid to give it a charge? Any wiring explinations or shortcuts or ideas how to get what I would call just crank and charge like a lawnmower or the cub cadet 102???
ronald wendel
08-05-2004 05:09:21
 Re: Club Car golf cart starter generator HELP! in reply to Steve, 01-11-2001 16:41:03
My cub cadet (1992) when i push the gas pedal sometimes it takes a while to accelerate.
