CUB CADET CLUTCH
GEORGE
01-12-2001 14:48:56
I NEED TO INSTALL A NEW CLUTCH ASSEMBLY ON A CUB CADET MODEL 1200 TRACTOR. IS THIS EASY OR HARD TO DO, ANY ADVISE. BEST PLACE TO BUY PARTS, ECT. THANKS.
dvogt
01-12-2001 17:36:40
 Re: CUB CADET CLUTCH in reply to GEORGE, 01-12-2001 14:48:56
it's not the worst job , but still a pain , pull the moter then you can get the clutch assy. out , you will want to get new moter mounts they will be shot , they are $40 , throw out bearing $25 , disc $30 . use caution when removing the role pins in the driveshaft theres alot of sprin tention there check on www.ihcubcadet.com Madsons Garage they should have all you need
