Gard'n Mast'r
Mike Dollard
01-13-2001 16:38:21
I am seeking any info, pictures, or owners of early Gard'n Mast'r Model G tractors, 1951 or earlier. I am looking for help with missing pieces of the Roto-Lock lift used on early Model G's. The Model G's equipped with this lift have a brake pedal, not a brake lever.
Gard'n Mast'r Model G tractors were built from 1951-1960 and possibly longer. To determine the year of manufacture, check the flat bosses on the upper rear part of the case that houses the 4 drive belts. One boss will have either G-B for Briggs & Stratton engines or G-W for Wisconsin engines. The other boss has numbers stamped on it. The first two numbers denote year of manufacture, the remaining numbers are the tractor number.
Jim Browning
01-03-2004 06:47:04
 Re: Gard'n Mast'r in reply to Mike Dollard, 01-13-2001 16:38:21
I have a Gard'n All that my Dad and I bought about 30 years ago. Its a 1952 with a brigs and Stratton engine. Its mostly original, still green with orange wheels and trim. We only drove it in a couple parades and its set ever since. It doesn't show much sign of use as the steering and all is quite tight. It has a plow but i'm not sure thats original equipment.
I'm thinking about selling it on ebay as I don't use it and need the room. Any ideas on that?
Thanks
Jim
