Deere mowers
Kevin F
01-16-2001 18:51:17
I am going to purchase a new mower and am looking only at Deere. My question is does anyone have a 325 with a 54inch deck? How does it handle it? Dealer says he doesnt recomend it because Deere doesnt offer it in their dealer book. Deere web site says it is available. They offer a 54 on the GT235 which is the same horse but a lighter frame.
Junkman
01-28-2001 20:42:02
 Re: Deere mowers in reply to Kevin F, 01-16-2001 18:51:17
I have a JD 445, 22HP with a 60" deck. Cost is a little more than the 300 series but I think it was well worth the difference. Buy the most tractor your budget will allow you.
Mickey
02-05-2001 17:03:13
 Re: Re: Deere mowers in reply to Junkman, 01-28-2001 20:42:02
I too love my 445 and on the picture below, you can see the front bumper a friend and I made from a 4100.
Chris
01-21-2001 13:38:10
Kevin,
I have a 345 with a 54" deck. The 345 is basically the same as the 325. I like the width. I imagine it helps shorten my cutting time a little.
I did add a grass/leaf catcher attachment which has a large blower fan assembly mounted on the discharge end of the mower deck and is belt-driven driven from the one mower pulley. The weight of this blower assembly tends to cause an uneven cut on a few steep inclines in my lawn. Without the blower attachment the mower stays balanced.
I would like to mention my disappointment in the mounting design of the mower clutch on the 325-345. My clutch vibrated against an alignment pin. Over 2-years this noise increased. In investigating I found the top clutch mounting plate had chiseled away at the alignment post attached to the frame and widened the slot on the mounting plate where the pin fit through. The alignment post holds the clutch in place when the mower is engaged. To help fix this, I had the slot welded to the original clearance. This held for another 2-years, then the clutch burned up. The problem had been that the chiseled post still allowed the clutch to vibrate and cause uneven wear on the clutch plates.
I bought a new clutch for $150 and welded the top plate so the metal surface is much thicker where it rests against the post on the frame. I also welded metal on the grooved post and ground it to give a slight gap between the clutch mounting plate and the post when the clutch is attached. This repair is only 6-months old, but I think increasing the thickness of the metal where the clutch vibrates against the post will prevent the damaging chiseling action.
I basically like my 345, but I tend to think for another $1000-1500 I should have gotten a 400-series...
You may want to look closer at a 400-series or another brand. When I emailed and spoke with John Deere customer service concerning my trouble with the clutch they were of no assistance, nor did they seem to care. Local John Deere mechanics were very aware of this clutch problem and were helpful in suggesting a resolution. I'm beginning to think John Deere corporation cares significantly less about their lawn tractors than their farm and commercial equipment.
Chris
Curt
01-17-2001 07:52:34
I have a 325 with a single cyl 17 hp Kawasaki and a 48" mower deck. I think that the 325 could handle the 54" deck if you are only mowing a lawn. I don't think it would have the guts for high grass or weeds. I can knock down 2 or 3 ft. weeds with my deck raised and then finish them off with a second pass. Engine grunts a little but it gets the job done.
MrG
01-18-2001 11:34:09
 Re: Re: Deere mowers in reply to Curt, 01-17-2001 07:52:34
Also consider the "lay of the land"... a wider deck can't adapt to contour as easily as a narrower deck. If you lawn is flat and level, no problem, but if you have uneaven dips, terraces, and swales, you may find yourself scalping in some spots and missing the cut altogether in others.
I have a 46" deck on a JD240 (14hp Kawasaki) and it seems a good fit for horseposer and tractor. My 317 has a 48" deck, also a good fit. My 322 has a 50" deck, alot of deck, but also alot of tractor. I think a 54-60" deck would be a better fit for a 400 series tractor. IMHO Gadget
