3 Point Hitch Catagory 0
Earl Wingert
01-17-2001 06:22:05
I am looking for dimensional information for a Catagory 0 3 point hitch. I would like to make the hitch for my Ford 120 Garden tractor.
Ron H.
01-25-2001 08:33:47
 Re: 3 Point Hitch Catagory 0 in reply to Earl Wingert, 01-17-2001 06:22:05
Earl,
The American Society of Agricultural Engineers (ASAE) has published a standard to be used when designing these hitches. A copy will cost you $28 but will provide all the specifications to make your hitch project a success.
Ask for standard:
Category 'O' Three-Point Free-Link Attachment for Hitching Implements to Lawn and Garden Ride-On Tractors ASAE S320.1 December 1999
Contact information to order this is:
ASAE Order Department E-mail: martin@asae.org
2950 Niles Road
St. Joseph, MI 49085-9659 USA
Phone: 616-429-0300 Fax: 616-429-3852
(8 am to 5 pm Eastern Time Zone)
After hours leave voice mail message.
I have ordered from them in the past and have gotten great service.
Other useful standards are:
One-Point Tubular Sleeve Attachment for Hitching Implements to Lawn and Garden Ride-On Tractors ANSI/ASAE *S348.2 December 1995
Agricultural Wheeled Tractors--Front-Mounted Linkage ASAE *S513 December 1999
2000-RPM Power Take-Off for Lawn and Garden Ride-On Tractors ANSI/ASAE S370.3 February 1996
2000-RPM Front and Mid PTO for Lawn and Garden Ride-on Tractors ASAE S431 December 1999
Application of Remote Linear Control Devices to Lawn and Garden Ride-on Tractor Attachments and Implements ANSI/ASAE S377 December 1995
Good Luck,
Ron H.
Kraig
01-18-2001 10:19:49
As measured from an Allis Chalmers 620 garden tractor:
Category 0 dimensions
Upper arm width center to center 15"
Upper arm length 6" (center of pivot point to center of lift arm link attachment pin)
Lower lift arm width center to center 13.75"
Lower arm length 21" (center of pivot point to center of pin attachment hole)
Upper lift arm pivot point is at a point 10" above and 6" rearward of lower lift arm pivot point
Lift arm links - 12.5", adjustable + or - approximately 2"
Lift arm links attach at rear end of upper lift arms and at a point 5.25" forward of the center of the lower lift arm pin attachment hole
Stay chains attach to lower lift arm at a point 3.5" forward of lift arm link
Top link attachment points are 0.75" and 2" below upper lift arm pivot point (two attachment points offer options for different implements)
Top link attachment points are 1.75" rearward of upper lift arm pivot point
MrGadget
01-18-2001 11:27:53
 Re: Re: 3 Point Hitch Catagory 0 in reply to Kraig, 01-18-2001 10:19:49
Some additional specs (from Research & Info on the left sidebar of this page):
Category 0 For Tractors with up to 20 Horsepower
Top Link Pins are 5/8 inch in Diameter
Lift Arm Pins are 5/8 inch in Diameter
Gadget
