Cub cadet ignition wiring
John
01-20-2001 16:01:08
My problem is I have totally rewired my 125 cub ..the ingnition wires are..L from the voltage regultor..1 wire from the solenoid...and 1 wire from the + coil... the new ignition switch reads as follows ... bat..ign..acc..and in the middle st... my problem is which wire goes where????..any help would be greatly appreciated ...Thanks in advance ...John in New Mexico
Roy Mottola
01-21-2001 07:13:37
 Re: cub cadet ignition wiring in reply to John, 01-20-2001 16:01:08
John, I have here a diagram for a model 129 which is the same as a 125 except for the transmittion. ST (orange)goes to PTO safety switch, BAT (light green)goes to negative on charge indicator,IGN(dark blue,and black)goe to electric lift attachment and ignition coil respectively.If you need the diagram email me directly as I can't figure out how to send the diagram through this message board
Roy Mottola
Jim S.
01-23-2001 06:10:24
 Re: Re: cub cadet ignition wiring in reply to Roy Mottola, 01-21-2001 07:13:37
Roy, but there's a whole lot more different between the 129 and 125 than the transmission. The 125 is a narrow frame tractor, the 129 is a wide frame. Just for starters.
tony fehlen
07-01-2005 13:53:57
 Re: Re: Re: cub cadet ignition wiring in reply to Jim S., 01-23-2001 06:10:24
does anyone have a wiring diagram for cub cadet 129?
