Engine replacement for JD 300
Roy
01-29-2001 20:49:40
Anyone replaced a Kohler k341 on a JD300 with a different type engine, perhaps a later Kohler or some other brand? My K341 needs rebuilding and I would like to have the oil filter.
RayP
02-05-2001 16:47:58
 Re: Engine replacement for JD 300 in reply to Roy, 01-29-2001 20:49:40
Can't speak to your particular unit, but I have a JD 140 which we repowered with a Briggs Vangard V-Twin 18hp. Chack with a small motorshop - they will have mounting and dimmension catalogues which will enable you to determine fit. (By the way, my unit works wonderfully well.) Good luck.
MrGadget
01-30-2001 11:52:11
The 300, 312, 314, early 316, and the 317 all share a common frame. You should be able to easily repower to a larger Kohler. Look to Padgett's (often found on ebay) for the KT17 Series II. This engine has a pressurized oil system with an optional oil filter. Gadget
