Craftsman/Roper transaxle
Jay
02-04-2001 19:57:41
I will try another posting. I have a 1982 Craftsman Tractor. It has a 20 HP Onan engine and I have established that the tractor is actually a Roper. My transaxle has packed it in and rather than rebuild it, I would like to throw a used one in. I cannot prove what type of transaxle it is. Everyone tells me it is a peerless but I bought the manual for peerless transaxles and mine is not there. It may be a peerless, but it isn't included in the manual. I can go to the Fridgidaire website and type in part numbers from my Sears manual and have the parts appear as a stock item. Since Fridgidaire bought out Roper which bought out AYP, is my transaxle still a peerless or something else? It has a 3 forward, 1 reverse gearing with Hi and Lo. There are no markings on the transaxle or casing.
sonny
02-20-2001 20:55:43
 Re: Craftsman/Roper transaxle in reply to Jay, 02-04-2001 19:57:41
your transaxle is a roper transaxle, you can still get parts for it under roper part #'s thru a co. like dixie sales. get me a fax# and i can get you a parts breakdown and part #'s. that transaxle is still made today in some different case configs. but internally pretty much the same look at husky gear drive garden tractors, sears, and american yard products at some of the home improvement stores . go to a dealer and see if they have any old dead sears tractors lying around they have been using that transaxle since about 1968 they are a very good unit to purchase parts from dixie sales you have to go thru a dealer ship.
Chris Ainsworth
11-23-2004 12:28:05
 Re: Re: Craftsman/Roper transaxle in reply to sonny, 02-20-2001 20:55:43
I have a sears tracter
917-250032
Onan Engine
sears diagrams show the transaxle is a AYP.
I want to change gear oil, since it is howling a little. But I do not know what to put in it.
It has a tag on one of the bolts. So is this a limited slip type, which takes a different gear oil. I hope you can help me, I need to know what oil to put in it.
PLEASE AND THANK-YOU
CHRIS
Jay
02-23-2001 18:52:48
I don't have a fax number anymore so unless you want to send me mail with the info. I am really interested in a transaxle manual. The general manual is too basic and seems to lack gears and shafts that are in the transaxle. In addition, I need only replace my broken axle which I could have made up for much less than the purchase cost through Sears, but I wanted to throw in a used transaxle to give me some time. I can get a transaxle from a gentleman in Michigan, but shipping it here to Manitoba would cost about $50-75 US, let alone the additional cost of the used transaxle.
steve gothreau
05-07-2003 17:39:47
 Re: Re: Re: Craftsman/Roper transaxle in reply to Jay, 02-23-2001 18:52:48
I have a 1988 ROPER 16 hp yard tractor. I have the transaxle apart , needed to have a gear made looking for good illustration breakdown so ican put the thing back in working order.Any help would be great. type 917-1101902x part# 1884504980 is on the housing.
pete
02-06-2001 19:23:34
Well, te good news is most of what mught be wrong with it is still available from www.jackssmallengines or Ray's mowers in PA, check postings for address. The bad news is that these units are AYP manufactured and are not in any way shape or form Peerless. I just replaced some bearing in mine, and Jacks hooked me up
Good luck
Jay
02-07-2001 06:23:13
 Re: Re: Craftsman/Roper transaxle in reply to pete, 02-06-2001 19:23:34
I only have needle bearing cups at the end of the shafts. One axle sheared off and I don't currently have the facilities to rebuild it 'cleanly' until I move soon. The axles ride on bushings.
Jay
02-06-2001 06:28:51
Am I out of luck with this?
Andy Wood
07-31-2002 21:49:38
 Re: Re: Craftsman/Roper transaxle in reply to Jay, 02-06-2001 06:28:51
The transaxle in the earlier Roper tractors that are 3 speed with reverse and high and low range were built by Tecumseh. Hope this little bit of info can help.....Andy
