Cub Hydrostatic problem
John
02-21-2001 15:39:21
I have a cub cadet 125 with Hydrostatic transmission .. It moves forward and backward but very slow and ..has a whine to it ... the trannny fluid is full to the threads on the plug....any suggestions would be greatly appreciated ..thanks in advance John in New Mexico
M. G. Burg
07-02-2002 20:04:24
 Re: Cub Hydrostatic problem in reply to John, 02-21-2001 15:39:21
I have a "CC 1110" and I had the same problem last year...V-E-E-E-R-R-R-Y SLOW FWD and RVS...problem turned out to be...the drive pulley on the tranny...it had worn so-o-o-o bad, that it had no way to grab the belt at all...even when I had the "tensioner" all the way in AND a NEW belt...I had the dealer do the work...good thing too! The pulley had 'seized' and they ended up breaking the pulley into three pieces to get it off. They put a new pulley on and it's been running great since...hope this helps.
Mark
RayP
02-25-2001 17:12:01
Does the cub have a by-pass valve to allow the tractor to be moved without the engine running? If so, check it for proper operation, setting, etc.
Jim S.
02-22-2001 05:29:13
First suggestion is to change yer fluid and filter. Use only HYTRAN as yer fluid. Drain by removing rear cover. Clean any gunk off bottom of trans case interior. Be sure it is immaculate before you put cover back on.
