Crankshaft install alignment of timing marks
max
02-28-2001 16:27:54
I have a kohler k321aqs that has never been tore down before. I am rebulding myself and have been using a small engine guide.but the guide isnt to clear as to which mark on the crankshaft to use. according to the book all k321s used counter/bal. shafts. mine did not have, there are two Marks on the crankshaft and one the cam. the cam shaft is self expanatory but which one on the crank do i use. Can Anyone Help.....
don
03-01-2001 05:00:22
 Re: crankshaft install alignment of timing marks in reply to max, 02-28-2001 16:27:54
use the larger mark closer to the gear teeth...don
