Craftsman peerless transaxle- oil added and no longer drives
bill
03-03-2001 12:40:07
My Craftsman model # 143.930-009 peerless transaxle was VERY difficult to shift. I pulled the plug and added about 1/2 quart of 90wt gear oil. Now the tranmission is easy to move through the shift points but there is no drive through the axles. It's a great driven manual transaxle? Did I screw-up by putting oil in the transaxle?
Brian
03-04-2001 10:29:50
 Re: Craftsman peerless transaxle- oil added and no longer drives in reply to bill, 03-03-2001 12:40:07
I might have a used one I need all your model numbers is it a 5 or 6 speed how old is it I may be able to help.
Ed
03-30-2002 09:32:03
 Re: Re: Craftsman peerless transaxle- oil added and no longer drives in reply to Brian, 03-04-2001 10:29:50
I have a Murray with peerless hydrostatic. My problem is I can't find anyplace to add fluid. Help?
MIKE'S MOWER
03-04-2001 06:18:22
PROBABLY DIDNT HURT IT ANY WORSE, THAT TRANY HAD A SORT OF SOLID GREASE IN IT! MAKE SURE THE BELT DIDNT COME OFF!IF IT DIDN'T THEN TRANY NEEDS TO BE TORE DOWN A NEW ONE RUNS ABOUT $450. USED $75-200.
Keith
03-04-2001 06:43:54
 Re: Re: Craftsman peerless transaxle- oil added and no longer drives in reply to MIKE'S MOWER, 03-04-2001 06:18:22
Bill No harm was done but the trans will probably leak. you may need to tear it down to find out why it wont drive (is the belt still in place?) Mechanics handbook TECUMSEH PEERLESS MOTION DRIVE SYSTEMS covers all of these drives. It should be available at the local Tecumseh dealer. The correct grease is sold as "BENTONITE GREASE". Does any reader know it by another name? Hope this is helpful Keith
G06043@AOL.Com
Pat
03-04-2001 08:58:12
 Re: Re: Re: Craftsman peerless transaxle- oil added and no longer drives in reply to Keith, 03-04-2001 06:43:54
There are usually a few of these drive system manuals on e-bay at any one time, although some of them are starting at more than a new one at the dealer (and still attract bidders!), but others go pretty cheap. I have only heard the grease referred to as Bentonite as well, Keith.
Lee Dunbar
02-07-2002 12:25:12
 Re: Re: Re: Re: Craftsman peerless transaxle- oil added and no longer drives in reply to Pat, 03-04-2001 08:58:12
Searched the internet using Google, searched for "what is BENTONITE GREASE".
First Link I found is for www.tsmoly.com
T. S. MOLY LUBRICANTS, INC.
P. O. BOX 230225
HOUSTON, TEXAS 77223-0225
TEL: (713) 671-2676 (800) 508-5545
FAX: (713) 671-9417
Their website is kind slow right now, try for yourself.
