Ford 100
no spark
nodak
03-04-2001 19:28:03
Just got a Ford 100 (free and delevered) has a blade, part of the tiller, chains, some odds and ends, but no spark. What do I need to check?
thanks in advance
Dave Jabs
11-11-2005 18:48:57
 Re: Ford 100 - no spark in reply to nodak, 03-04-2001 19:28:03
replace the coyel and the wier i had the same prob and i did what i just sead and i worked.
john
04-01-2001 15:36:22
Check to see if there is power to your coil on the positive side,but your test light on the negative,turn your engine over see if your light blinks,if it does't,replace the points gap is 16 thousands,spark plug is 25
Joe
03-05-2001 05:41:25
replace the points and condencer and see what happends good luck JOe
