Ford 100-no spark
nodak
03-10-2001 18:38:09
does a ford 100 have points that may be warn? THANKYOU
John
03-11-2001 11:42:11
 Re: ford 100-no spark in reply to nodak, 03-10-2001 18:38:09
Give me some more info on your engine ... I also have a ford 100 ..mine has a 10 hp kohler ...if you have an external coil..follow the - negative side of the terminals, a wire should lead you to the points...email me if you have more questions ...John
john
04-01-2001 15:18:12
 Re: Re: ford 100-no spark in reply to John, 03-11-2001 11:42:11
The points are located on the left rear side of the engine,under a cover with a rubber seal in the side of it,to keep the moisture out.The gap is 16 thousands,plug gap 25.If you know where I can get a lift hicth for the back,let me know.
