Checking transmission fluid on a JD300 LG
frank b.
03-23-2001 07:24:07
I have purchased a 300 john deere L&G with a 3pt hitch. The dipstick in the transmission was in bad shape and looked like a choke cable housing attached to the cap. I ordered a new dipstick and it's a flat one with marking for full etc. However the new stick is a tight fit in the full tube. Also in the manuel it says to check fluid with the tractor shut off but warm. when I removed the dipstick fluid runs out of the fill pipe. Do I have the right dipstick? and what is the correct prodecure for checking the fluid level?
thanks
frank b.
