Cub cadet solenoid problem
John
03-23-2001 17:33:19
I have a battery ignition on my kohler 12hp...when key stays on ...fire stays threw all the way to starter....I think its the solenoid....I have another solenoid.that is new...but the new one has two small poles instead of only one like the old one.... does a wire have to be hooked up to both small poles in order for the new one to work ????.and if so what wire goes to the other pole???..... thanks for your help .....John
Bob
04-06-2001 11:31:51
 Re: cub cadet solenoid problem in reply to John , 03-23-2001 17:33:19
Use terminal labeled "S", ignore terminal labeled "I"... not needed in your application!
don
03-24-2001 05:10:43
you dont have to use the second small pole,,,in most cases its for the ignition wire so you get good current there when cranking...don
