1964 Cub Cadet Lawn Mower
Model 102
Susan Lancaster
01-26-1999 06:03:02
My father has a Cub Cadet LM. It seems that the shaft that holds the main pulley on the mower deck is defective. It does not have a nut or anything on top of the shaft to hold the pulley on. Every time he usese the mower the pulley comes off. Can you tell me what the part number is for this and if there should be a nut or something on top of the pulley. It seems we can't find anyone in the general area that has any knowledge about this?
Jeff...
01-26-1999 10:08:20
 Re: 1964 Cub Cadet Lawn Mower - Model 102 in reply to Susan Lancaster, 01-26-1999 06:03:02
The main pully on the 102 mower deck is held in place by a special fine thread bolt. The bolt is special as it has a hole down the center and a grease zerk is fitted to the bolt head, this inables you to grease the spindal bearings. The part/bolt is still available at any IH/Case dealer . Good luck if you need any more info email me...I have 3 of these suckers
JK
keck
01-26-1999 07:03:10
yes there sould be a nut to hold the pulley on
take it back to your deal if he bought it new
they will have the part number. you my need a new
pulley too.
ERB HENRY EQUIP INC.
01-28-1999 08:20:31
 Re: Re: 1964 Cub Cadet Lawn Mower - Model 102 in reply to keck, 01-26-1999 07:03:10
HI SUSAN IF YOU NEED ANY PARTS WE ARE A CUB CADET DEALER WE HAVE NEW & USED PARTS AND IF YOU HAVE ANY QUESTIONS WE WILL BE GLAD TO HELP PH# (610)367-2169 FAX (610)367-6715
