Cub Cadet 682
Zac
04-01-2001 18:09:41
The engine in our 682 is all tuckered out.We snapped a rod and all the chuncks pretty much tore up the inside of the crankcase.I think the motor has pretty much had it.I don't really want to shell out a bunch of money on a new engine.Is there anyplace I could find a good used motor out
of either a 582,682,or 782? Thanks, Zac
dvogt
04-02-2001 19:10:07
 Re: Cub Cadet 682 in reply to Zac, 04-01-2001 18:09:41
since the kt 17 was basicly a pile of garbage to start with unless you can find a decent used series 2 moter don't waste your money , just buy the new moter , from what I've seen no one parts them out unless the moters bad
Justin Angel
03-14-2005 18:22:58
 Re: Re: Cub Cadet 682 in reply to dvogt, 04-02-2001 19:10:07
you should first checkout the crankcase, and the oil pan. If not too damaged, you can replace the rod, along with the bearing cap. You end up spending about $50.00 if not too much damage.
MrG
04-02-2001 13:53:34
The best thing you can do is get a new Series II or Magnum replacement for Padgett's or that guy in Tulsa that's selling them. YOu should be able to get one for $1,200-$1,300. Drop it in, hook it up, and run it! Gadget
Tim Lambdin
04-11-2002 19:45:17
 Re: Re: Cub Cadet 682 in reply to MrG, 04-02-2001 13:53:34
KT 17 a piece of junk ? first time ive ever heard that one ! you can order a small block and use your existing intake,exhuast ect. takes about 2 hours to do no need to buy a whole new engine! golly where do these people come from.
