Battery won't charge
lou frohlich
04-02-2001 16:53:45
i have a rally lawn mower with a 10 hp briggs& stratton engine. the battery won't charge can somebody tell me what.s the problem?
John Wilhelm
04-08-2001 19:06:35
 Re: battery won't charge in reply to lou frohlich, 04-02-2001 16:53:45
Charging circuits on small engines are designed to work only partial to fully charged batteries. A flat battery will have too resistance to take enough current to charge the battery. Before you replace the charging circuits in your engine try a fresh fully charged battery. The charging circuit should charge the battery at least at 1 ampere or more with the engine running at full speed. If the battery is 3 or more years old get a new one. They are cheap enough at places like Sams Club.
Bob
04-04-2001 06:14:39
I would start with cleaning the contacts like where the ground connects to the frame. Then where the leads connect to the battery, make sure that they are good and free from any oxadation. If you have a trickle charge generator connect that next to recharge the battery. Bob
