1967 Cub 102 model
Mark
01-26-1999 19:43:57
I have a 67 cub model 102 from what i have found out. It had a Kohler 10 hp shaft drive,3speed trans. What info can anyone give me. It is all Stock. Such was Gear ratios and such. thanks
bill grote
02-04-1999 19:06:55
 Re: 1967 Cub 102 model in reply to Mark, 01-26-1999 19:43:57
hi Mark I have a 102 - just rebuilt the engine for the first time- that synthetic oil seems to make them last a long time. it has been a very good machine, the clutch spring needs to be replaced once in a while but not much else.i have copies of the original manuals.
CADET MAN
01-28-1999 15:37:10
102 BUILT in 1965-1967.serial#127161-218009.three speed is stock.gear ratio i have to dig deeper
CADET MAN
01-28-1999 15:31:26
It sounds like it is stock.The 102 was built in 1965-1967 seial# 127161 to 218009.three speed was the on only trans on the 102.For gear ratios i have to dig deeper.
don
01-27-1999 05:07:40
3=32-1,2=56-1,1=92-1 has 10 hp kohler engineif you are going to use it for tractor pulling in stock class you may want to consider the slow 2nd gearfrom a older model witha tooth count of 16or 17 this would give you 68-1 or72-1
