Can I check rpm's with a car tach?
Fred Miller
04-17-2001 11:50:08
Hi,
I maintain my neighbors little JD 165 garden tractor. JD talks about a vibration tach in the manual for setting the carb up. The local dealer doesn't think much of the gadget. Is there some way to use a automotive test tach on the mower and if so, how would I hook it up?
Thanks,
Fred
ACE
02-06-2002 18:53:40
 Re: hard starting Kohler MV-18 in reply to DaChew, 01-02-2002 09:25:51
VAULVES ARE HYDROLIC.IF BOTH CYLINDERS ARE LOW ITS A BAD SIGHN.INTERNAL DAMAGE.THERE IS NO COMPRESSION RELEASE ON THESE ENGINES
Jim S.
04-17-2001 13:14:28
 Re: Can I check rpm's with a car tach? in reply to Fred Miller, 04-17-2001 11:50:08
The Vibra-Tach will give accurate readings within 50 rpm of an electronic tach. I highly recommned them, as do a number of professional small engine mechanics. They cost as little as $9 to as much as $20 and come reboxed in a variety of packaging. All are the same units, made in Germany. Tecumseh sells one in their box that seems to be one of the cheaper ones.
I dunno what your dealer is thinking about...these have been used satisfactorily in small engine shops worldwide for many years. Remarkably simple concept, rugged, accurate, cheap. What more do ya want?
Eric
04-17-2001 15:01:53
 Re: Re: Can I check rpm's with a car tach? in reply to Jim S., 04-17-2001 13:14:28
I'm getting a job at a JD dealer so i'll try these out and let ya'll know how my experience is with them. They do work on any engine, right? Are they just for testing or can you mount it permanently on a tractor? Does it use any batteries and if so, the tractor one or a watch battery or AA batteries or what? Is it analog or digital? if you don't know all the answers, that's ok, i can see at the dealer that i'm getting a job at, and let you know. I have seen the small engine digital tach and hourmeter combo, the one that is sold in Northern tool and equipment and other places for about $30-$40, and was going to get one of those. It shows the rpms when it's running and the hour-meter when it's turned off. It runs offa watch battery, which is supposed to last about 3yrs or so. I was going to get one of them, but this vibra tach sounds interesting and cheap. but i'd still like an hourmeter... not terribly important, but nice for maintenance schedules. Let me know what you know about it. Thanks,
Eric
Max
01-28-2002 17:25:31
 Re: Re: Engine for Case 446 in reply to Les, 01-27-2002 18:20:11
Wow, yours must not have been setup properly and someone must have stolen your operators manual before you got a chance to read it. The manual gives details on how to operate down a hill. Biggest problem I ever had with mine was the lack of weight which was remedied by adding water to the rear tires. I've never had problems with my ignition key getting hot either, just the hood over the muffler. The only thing special about the Onan is the flywheel for the front pto and a 1-1/8" output shaft for the hyd pump, the rear mounts are standard SAE bolt pattern.
dan
01-25-2002 10:56:28
 Re: Re: Re: country squire in reply to bug, 12-23-1999 09:46:18
i would like to communicate further on your "treasure" they are a little work horse, i use mine to plow snow plus summer duties.
they were built in muskego wisconsin. i am also
looking for parts and literature concerning this
unit. please feel free to contact me. i have just
replaced the trator tires found out 8-16 front
wheel drive tires perform well, on the rear.
dan
Cowboy Bill Watts
02-01-2002 13:39:36
 Re: Re: Re: Cub Cadet 1000 in reply to smoker , 01-31-2002 15:40:04
well, it's worth like $10,000,000,000,000,000 just like it sets it you're willing to sell it.
think i'm kidding? i'm not. the market for old cubs is huge.
