782 Hydrostat
Bob Wagner
01-29-2002 10:09:56
I have a 782 that is leaking out of the top of one of the 2 valves (top front of engine) It is now only working in reverse and won't go forward.
Do I need to repace this valve? If so I am looking if you have one.
Bob
Jim S.
01-29-2002 10:17:41
 Re: 782 Hydrostat in reply to Bob Wagner, 01-29-2002 10:09:56
Try putting the engine on full, ramming it forward, then ramming it backward. Watch out for wheelies. Do it in rapid succession, this will frequently pop loose a stuck valve, which is why it won't go forward. It may stop leaking once popped loose. Works best on gravel!
You can reverse the valves in the holes, so you will have forward but no reverse.
You can also take the valve out, use PB Blaster on it and soak it to try to loosen it.
The valves are available new, too, if you can't get it loose or to stop leaking. I think they are around $75 each.
