Re: Re: Re: Re: adding hyd valve to jd 300
Al
02-09-2002 04:46:19
Hi Kent,
I like what you say,cost wise to,but I am not clear on how to keep the 3pth from cycling if using the front remote.I'm thinking a pin to lock the hitch in the up position then unplug it's cyl.I have never seen a factory set-up,these machines a rare in my area and the dealer don't have staff that even remember the 70's.
Thanks
Al
Kent
02-09-2002 14:10:48
 Re: Re: Re: Re: Re: adding hyd valve to jd 300 in reply to Al, 02-09-2002 04:46:19
Hi Al. If you want, go over to the weekend freedom machines JD garden tractor site & look in the model info section under factory attachments, there should be a picture there of a 140 3pt setup, and maybe also a pic under 300 series. Basically they were the same hitch, except for the 300 series they were notched for gas tank clearence & the hoses hooked up just above the hitch plate, rather than through the rear of the fender deck like my 140. Since I take it you are building your hitch, I would suggest going the route of making it pinnable in a somewhat raised position to unhook the hoses, or make/buy some spacers to fit around the ram when it is in the position you want, then unhook the hoses. My dad does this alot on some of his farm equipment, using a piece of channel iron that will fit around the ram far enough that it has 2 hole drilled through it for a small pin to keep it on after it is placed around the ram, meaning the two sides are deep enough to allow this. Hopefully you understand what I mean. I also know that farm stores sell some aluminum round pieces that are split & held together with a spring, so you spread it apart to fit it around the ram & then it snaps shut. These come in 1/2", 1" and other assorted hights. I hope this helps.
Kent
