5 HP Briggs-Straton fuel problem
Kenneth Allen
02-10-2002 18:47:36
My 5-hp BS on my garden tiller seems not to be getting fuel. As long as I squirt starting fluid into the carburator, it will run which leads me to believe it is not getting fuel.
Have tried to take carburator off but after taking the screws (3) out from the top of the tank, the carburator turns about a quarter inch and stops. Afraid to force. Any suggestons on how to remove from the fuel tank?
Mac
02-11-2002 06:37:21
 Re: 5 HP Briggs-Straton fuel problem in reply to Kenneth Allen, 02-10-2002 18:47:36
After removing 3 screws Carb. should just lift out of tank. Sounds like you need a new diaphram if you are not getting fuel in the way you describe. Oblong plate on the side of the Carb.
4 screws if I remember. You can change this without removing the Carb. Probably a couple bucks. Watch for the spring behind diaphram.
ds549@webtv.net
02-11-2002 06:46:08
 Re: Re: 5 HP Briggs-Straton fuel problem in reply to Mac, 02-11-2002 06:37:21
some of those carbs had a screw in the intake port where the air filter mounts,,,diaphram is a must..lucas
