Cub 1000 Clutch problem
Sam V.
01-27-1999 21:25:02
Had clutch completely rebuilt once, since repaired two times, out now. New parts/throughout bearing replaced but has always been difficult to stop shaft from turning. This tractor has not been worked hard. Slings the springs from pressure plate also. Any help appreciated.
CADET MAN
01-28-1999 15:21:56
 Re: Cub 1000 Clutch problem in reply to Sam V., 01-27-1999 21:25:02
Sam,make sure shaft fits in brass bushing on engine.Also make sure shaft isnt dented up on side that goes in engine,this usually makes shaft stick & spin.you can check to make sure your engine is bolted down tight.A loose engine will pinch shaft and cause it to spin.Anti rattle springs are hard to keep on I usually dont use them.I hope i helped.
Sam V.
01-30-1999 12:51:48
 Re: Re: Cub 1000 Clutch problem in reply to CADET MAN, 01-28-1999 15:21:56
Thanks for the info Cadet Man. I think you may be
correct about loose engine as once I pushed engine sideways and shaft stopped. The motor mounts may be out. I will check them.
Mark huffman
01-28-1999 05:01:46
Sam check out to see if there is a build up of dust and stuff around the motor side of the clutch shaft that was the problem with a 124 we had
Mark
Sam V
01-28-1999 15:11:57
 Re: Re: Cub 1000 Clutch problem in reply to Mark huffman, 01-28-1999 05:01:46
Thanks Mark, I will check for the dust buildup.
