Dating a OLD BIG Briggs Engine??
Mark Hendershot
02-19-2002 17:05:20
I have a Old Briggs Engine Gold in Color with Easy Spin on it. Rope start and appears to be around a 10-15 HP in size?? What do I look for or is there a number and a way of finding the HP, Year of the engine. Maybe a code number spec. sheet web/site? It is on the Mighty Mite Tractor. Thanks, Mark H.
Tom
02-22-2002 16:53:44
 Re: Dating a OLD BIG Briggs Engine?? in reply to Mark Hendershot, 02-19-2002 17:05:20
Should be nubmers stamped on the tin cooling shrouds or tin. Usually on the recoil start housing, near the head, or on the side, but sometimes on a tin panel on the side of the cylinder. It also acts a shroud to direct air flow around the cylinder. Should be a model, type and code #. You can obtain the info you need from those numbers. Might have to do a lot of cleaning off of paint and such to see them...
Darren
02-28-2002 20:24:58
 Re: Re: Dating a OLD BIG Briggs Engine?? in reply to Tom, 02-22-2002 16:53:44
If the engine was made after 1952 the year of production is indicated by the first two digits of the code #
