Electric blade clutch
mucstak
02-20-2002 11:55:31
I have a wheel horse lawn tractor, about 15 years old. It has an electric cutting blade clutch that has worked flawlessly till this year. It does nothing whrn I flip the switch. Where should I start troubleshooting?
john d
02-20-2002 13:07:34
 Re: electric blade clutch in reply to mucstak, 02-20-2002 11:55:31
Make sure the power is actually getting to the unit. The switch might be defective, and there should be a fuse somewhere in the line. Also check the ground wire. Mine breaks about every 3-4 years due to vibration.
brianh
02-20-2002 13:05:55
Use a meter or test light to see if you have battery voltage at the clutch hot terminal with the PTO switch turned on. If not, you have a switch or wiring problem. If there is voltage at the clutch winding but it doesn't pull in, it is probably bad. Check the winding resistance with an ohmmeter, if it is above a few ohms (probably infinite) it is definitely bad.
