CUB CADET 1000 QUESTIONS
John
02-22-2002 00:11:30
Im looking at an IH Cub 1000 from the original owner. Comes with deck, snow blower, weights and chains. In very good condition. All original. What is a very good price for a unit like this. Anything in particular to check for on these? Any known problems? Thanks, John.
jeff knapp
07-24-2003 15:33:15
 Re: CUB CADET 1000 QUESTIONS in reply to John, 02-22-2002 00:11:30
I can not find my owners manual for my 1641 cub cadet. was cutting grass and the belt, [for the mower] came off, can you help ? knee deep in grass
Denny Frisk
02-25-2002 12:59:50
I can't tell You what the tractor & attachments are worth... but I can tell you no company makes a tractor as durable as the 1000 anymore! The 1000 is a 10 HP Gear Drive "QUIET-LINE" Cub Cadet that the engine was mounted on a cradle supported by 4 rubber bushings. These bushing wear out and the engine can rock around. That movement causes the clutch disc to flex & crack. Parts are still avail. new or used but I know the clutch disc is expensive on that tractor. The K-241 AS Kohler engine is bullet-proof. The tractor should have side panels over the engine and shrouds over the engine inside the side covers & under the hood. These shrouds should be in good shape too, no cracks or missing pieces. Also make sure the starter engages the flywheel O-K. It's actually a small Bendix type starter like a car as opposed to the Starter/Generator like on the earlier Cub Cadets. For more Info You can read posts & FAQ's at ihcubcadet.com LOTS of good info there.
John
02-25-2002 13:43:21
 Re: Re: CUB CADET 1000 QUESTIONS in reply to Denny Frisk, 02-25-2002 12:59:50
Thanks for the reply. I was going to go an buy it today but when I called the guy back last night someone bought yesterday. He was going to let me have it for $550. I thought a pretty good deal. Thanks again.
