John Deere 110 3 spd.
Al Dickey
02-22-2002 13:03:14
Has any one out there ever replaced this older style 3 speed transaxle with anything else?
Can a newer version of a hydrostatic inter-change?
How much work and is it fesilbe? Thanks loads...
Kent
02-22-2002 13:50:51
 Re: John Deere 110 3 spd. in reply to Al Dickey, 02-22-2002 13:03:14
Hi Al. I don't have actual experiance here, since I don't own a round-fender, but in the service manual, it says you cannot replace a 3 speed with the later 4 speed, because of frame clearance. Installing a hydro would be a massive butcher job in my eyes, seeing as how Deere never used a hydro that was belt drivin with a horizontal shaft engine (at least that I know of). That being said, I know that Peerless transaxles were very similer to other makes, such as the 3 speed Sears Custom 600 I used to own, other than maybe swapping out the shift lever/tower, it would have probably bolted right in a Deere. So if yours in junked out, I would say to look around at some different makes of tractors to see if they used a similer transaxle.
Kent
MrG
02-22-2002 16:30:12
 Re: Re: John Deere 110 3 spd. in reply to Kent, 02-22-2002 13:50:51
Kent, Al - I's be JDPuller could get hime fixed up. Click the ad on the top left corner at:
www.weekendfreedommachines.org
MrG
02-22-2002 16:29:19
