Cub Cadet 1650 LIFT EAR / ARM Wanted
Ron
02-26-2002 18:44:22
I have a 1650 with a factory 42" snow plow and would like to buy the lift ear that connects to the snow plow lift rod. It's located outside the frame on the rocker shaft which raises and lowers the blade. Fairly priced only please.
Jim S.
02-28-2002 06:01:59
 Re: Cub Cadet 1650 LIFT EAR / ARM Wanted in reply to Ron, 02-26-2002 18:44:22
Your 1650 should have a place for the blade control rod in the casting that the lift handle is connected to. It doesn't need an additional paddle-shaped piece like the narrow frames use. If that piece of your casting is busted, you need the casting or a complete lift handle assembly. Hope this helps.
