Bolens 1250 throttle cable attachment
Gary
02-28-2002 01:32:31
I have a Bolens 1250 that recently had the engine rebuilt and it's been so long since I took it apart I can't remember how the throttle cable goes back on. Any help would be appreciated. Thanks
Jeremy
02-28-2002 05:04:55
 Re: Bolens 1250 throttle cable attachment in reply to Gary, 02-28-2002 01:32:31
Gary,
The throttle cable is mounted on the right side of the dash. It runs along the right side of the engine and bends 90 degrees at the battery and gas tank. It then runs between the engine and gas tank over to the left side of the tractor. It then bends 90 degrees towards the ground. The end of the cable mounts to a rotating disk, which is connected to the govenor. If you need more help, feel free to email me. I could even take a few digital pics of mine. You might also want to check out the Bolens Tractor Group (link below). I have uploaded the manuals and other info on the 1250 into the group.
Jeremy
