Bolens G-152/Iseki
Jerry
01-28-1999 14:57:59
Does anyone know where I can get either a water pump or parts to fix mine? This Bolens has an Iseki Model KE70 two cylinder diesel engine.Engine serial # KE7013PS. It is a 1980 model. Iseki part number for the water pump is 5650-040-9302-0. Bolens was bought out by Garden Way, of Troy N.Y.(Troy Built) and they tell me they would have to order it from Japan, and it would take at least 6 weeks for it to get to N.Y. I hope someone has a better idea. Thanks.
J R
02-10-1999 19:33:13
 Re: Bolens G-152/Iseki in reply to Jerry , 01-28-1999 14:57:59
The KE-70 IS A Mitsubishi engine. I own a Mitsubishi tractor with the KE-70 engine. Try the Stull Co. in Coraopolis, Pa. They are Mitsubishi parts distributor. If you need, I can look up the
pump part number for you. Please e-mail me if you need more information
TONY KELLEY
02-02-1999 11:11:03
YOU CAN GET THE WATER PUMP BY CALLING (812)663-8928.
Gary
01-29-1999 05:49:04
I have one like it; that engine is a Mitsubishi. You might try finding one from them. You might also try Georgia auto parts at 703-654-3355.
Jerry
02-01-1999 18:09:50
 Re: Re: Bolens G-152/Iseki in reply to Gary, 01-29-1999 05:49:04
No Gary. Mine is an Iseki. The whole tractor is. It even says Iseki on the side right beside the Bolens. It is a 2 wheel drive. I have seen similar ones that were 4 wheel drive that were Mitsubishi though. It is actually an Iseki Model TX1300, and that is stamped on the ID plate, but on the hood it says Bolens G 152. Jerry
mike
02-02-1999 11:40:38
 Re: Re: Re: Bolens G-152/Iseki in reply to Jerry, 02-01-1999 18:09:50
I agree with Gary. The Iseki tractor models TX1300 & Tx1500 came with Mitsubishi engines.
