212 Bagger Match
Matthew Hutchin
03-05-2002 15:27:16
I am looking into purchasing a bagger for my JD 212 w/ a 46" deck (3 blade). I have found one for sale off of a 265 also w/ a 46" deck. It is a powerflow system, but it is in another town and I have not looked at it yet. Is this bagger compatable with my mower with slight modification?
Thanks,
Matthew
Dave
03-05-2002 16:02:37
 Re: 212 Bagger Match in reply to Matthew Hutchinson, 03-05-2002 15:27:16
Matthew - The model code for a Power-Flow for a 46" deck is MOOPFCB. This will be on a plate located on the blower unit that attaches to the deck. First, you need to verify the model code. Next, there are 46" decks that were sold on the 265 tractors, as well as STX model tractors. If the deck on the 265 is original to that tractor, and it is the same design as the one on your 212, the blower unit will most likely fit. (Blower units run $360+ new.)
The post that the bags and hopper cover mount to, however, differs between a 212 and a 265. I'm guessing it would run between $100 and $200 for the mounting parts (new from the dealer).
I'll try to e-mail you some additional information that should help. - Dave
