A special engine for a special machine
68 Mag
03-06-2002 10:45:34
Hi all. I'm looking for a single cylinder diesel engine that will fit into a Jacobsen 775 LGT.
I've designed the ultimate yard mover out of it, but it needs a powerplanlt large enough to drive:
2 transaxles for dual rear axles
A hi/ lo TA that I built, which is just a small pulley on top of a big one, on the transaxle
A power steering pump or two that I'm using to provide auxilary hydraulics for a dump bed, three point hitch, dozer blade, and 2 remote outputs.
A belt drive air compressor, just large enough to fix a flat tire
Depending on gearing, and since I wouldnt use them all at the same time, would a 16 horse gas engine do?
The TA is of my own creation. The high gear is 2 pulleys with a 1:1 ratio, for speed when transporting empty. The low for work is a 2:1 or better, for serious power but not much speed. The 2 rear axles are basically to support the weight of a wooden dump bed and a small, home made gooseneck flatbed trailer. The very rear axle may not even be a driving axle, and if it is, it'll be a solid 1 1/2 rod, driven by 2 chains off of the factory axle. I'm going to convert everything to chain drive except the PTO, which will have to drive-
A tiny compressor, assuming that I can find one.
A power steering pump or two, but no more than two. I need one for a 3 pt, and one for remote, auxillary hydraulics.
Once I get my engine, I'm going to devise a dual vertical exhaust with Farmall Cub mufflers and rain cap, and a primitive exhust-powered engine braking. The engine braking will simply be a ball valve before the T for the dual exhaust, to make it work.
Dual enhaust will be a threaded pipe out of the exhaust, then a 90* elbow, and various fittings until I have a vertical stack on each side of the hood, mostly for looks and my basic engine braking.
Am I crazy, or does this thing have a fighting chance of working?
68 Mag...:)
Greg
05-19-2002 05:17:25
 Re: A special engine for a special machine in reply to 68 Mag, 03-06-2002 10:45:34
You want a line on engines, try NET@SMALLENGINEDISTRIBUTORS.NET they have alot of engines and at a variety of prices, some take offs, others brand new in the box good luck Greg
rednekelmo
03-09-2002 09:31:54
try hatz diesels hatzusa.com
tom
03-07-2002 15:07:26
Nothern used to have some single cylinder diesels in there catalog. Not sure if they still do or not.
There was a couple 2 cylinder air cooled Deutz Diesels on ebay a while back. Might want to try those two and see what you come up with...
Pete in Ks
03-06-2002 12:13:12
No I don't think your crazy, but. First I do think you will find it hard to find a single cyl. 16hp diesel engine. If you do it will probly be larger than a more common 2 or 3 cyl. diesel motor. You should be able to find a 16+hp gas motor cheaper. Second it sounds as though you want one machine to do everything, which is something we all dream about occasionally but I have found it more fun to have a bunch of machines that do just one thing.:-) For your compressor look at an auto air conditioner compressor of the piston type. It will use a 12v electric clutch and you'll be able to turn it on or off at will or could be seup automatic on a preasure switch. Good luck.
68 Mag
03-06-2002 12:31:23
 Re: Re: A special engine for a special machine in reply to Pete in Ks, 03-06-2002 12:13:12
I'm building this machine to, as you said, do it all. I'll probably end up with a gas motor, but what worries me is it has to be large enough to move the machine with a full load of gravel in the dump bed, and a full load of firewood on the miniature gooseneck trailer. No, it will never be run like this, but it needs to have the power to...
For my dump bed, I'm using the hand operated hydraulic unit off of an old pallet jack. If the situation warrants, I may wind up adding a second battery to supplement lights, and electric compressor out of a car's AC unit. After thinking it over, it'll stay belt drive from the engine to factory transaxle. To put the TA in high, I'll stop, and cut off the engine. Lock the clutch 'down' with the parking brake, and flip up the modified seat on modified mounts to reveal the top of the transaxle where the pulleys are. I'll take the belt and pull it off the largest pulley and move it up to the next one. Then, I'll adjust the pressure pulley I'll have to add so the belt will fit the smaller pulley snugly, and not slip as much. Sound like it will work?
I'll need one, maybe two power steering pumps. I cant decide if I want to put a 3 pt on the back, or a hitch I made myself. It works like a 2" reciever on a pickup, but instead of 2" square tubing, it's 1" electrical EMT conduit. This would give me a lot of options on the rear...but I could always make a drawbar for the 3 pt with this hitch...
My engine braking is a really neat feature, to me. I'm designing it because basically, I want this to have the hauling (and stopping) power of a lawnmower sized big rig, but be able to go anywhere. I'm also designing dual rear wheels, but eight 15 inch Ag tires would be quite an investment...
Rambling,
68 Mag
