BS carb. Help Question
Dan
03-16-2002 12:08:24
This is a 6hp on my Vac.the gas runs out the carb like the float is stuck, i took the old float out because seemed to have a leak and put a new one in plus the needle.Itis still doing the same thing.Flo-Jet carb.
Doug
05-21-2002 04:53:39
 Re: BS carb. Help Question in reply to Dan , 03-16-2002 12:08:24
I had a very similiar problem but with a Tecumseh engine. First does your engine have a primer bulb on it? If so take it off, clean out the passages & put a new bulb & retainer on. Thats what I had to do for the Tecumseh. I did everything you did & the fuel still kept coming out. According to the Tecumseh manual a plugged atmospheric vent could be the problem. Well I couldn't find a so called atmospheric vent anywhere. I then got to talking to an older gentleman who used to work on small engines and he was the one that told me to replace the primer bulb & clean the passages. I did it, put it all back together and it has been running fine since. I hope this helps you out.
Doug
lucas
03-16-2002 12:53:02
the needle seat may be damaged or some dirt there keeping the neels from seating properly...if it has the brass seat they are replaceable,,instructions come with the new seat,,,lucas
Dan
03-19-2002 11:14:56
 Re: Re: BS carb. Help Question in reply to lucas, 03-16-2002 12:53:02
I put new needle ,floatand new seat in this carb and gas still flow out the carb. Dan
