Case 648 uk need info
mike
03-18-2002 05:06:08
I have a case 648 with d100 back hoe and front loader which I am restoring. Are there any others in the uk? I am unable to get any information on the tractor in this country. Simple things like where is the 'go' pedal spring fixed? How long is it unstretched? What is the small orange wire coming out of the altenator connector? What was the pedal inhibitor switch connected to? And how do you get the speed range lever into high? Help would be greatly appreciated.
BOB
03-28-2002 07:08:34
 Re: case 648 uk need info in reply to mike, 03-18-2002 05:06:08
MIKE HAVE U RECIEVED ANY OF MY EMAILS? I HAVE INFO ON UR MACHINE I THINK.. ALSO HAVE MANY QUESTIONS FOR U... I HAVE THE FULL FACTORY MANUAL... COMPLETE..... LOADER BACKHOE AND ALL..WRITE BACK... BOB
Max
03-18-2002 21:09:00
Can't remember all of the particularson the 648 but one thing in common with the other units is the transaxle. To ease it into high range, sometimes you need to roll it a little while puller up on the range level or slightly add a little fwd or rev hyd drive motion to get it to shift out of low range and then into high range. I don't know about the number there in the UK, but I jealeous of you for you having one. It was always one of my dream machines.
mike
03-22-2002 01:02:14
 Re: Re: case 648 uk need info in reply to Max, 03-18-2002 21:09:00
Thanks Max I'll try that.
