AG Tires
JMC
03-24-2002 22:53:49
I hear all the talk about these ag tires but am having trouble finding some for my JD210. Dont know the wheel size right off hand but am sure all 210's might be the same. How much am I looking at for the rears? How much for a whole set of rubber? Thanks in advanced, Jeremy
Brent
03-26-2002 12:00:22
 Re: AG Tires in reply to JMC, 03-24-2002 22:53:49
Check out www.gemplers.com They've got a good selection of ag and turf tires at reasonable prices.
John
03-25-2002 21:12:08
Finally bit the bullet and put Carlisle Super Lugs on my old Sears GT16. Made a BIG difference in traction, no question. Sorry I didn't do it sooner. I am using 23x12x10.5" and they work great.
Jim S.
03-25-2002 10:17:24
TSC carries Carlisle ags. You might want to check Titan out here. They have been very popular with others on various forums. CR Tire also has Carlisles.
Art
03-25-2002 04:46:31
Got mine from>Link
very>Link reasonable.....Art
Timmer
03-25-2002 04:38:00
I've seen most 200 series with 23-10.50*12 size tires. I can get a set of these for 49.99 a tire at Tractor Supply Company. Rims may cost from 20 to ? a piece depending on size.
Bruce
03-25-2002 16:41:25
 Re: Re: AG Tires in reply to Timmer, 03-25-2002 04:38:00
Been running 26x12x12 Goodyear ag tires for at least 15 years here in N.Y. Never have needed chains winter or summer. Do not tear up the lawn and never need to worry about slippage under any conditions. Cost about $50 per tire. You probably need 23x10.50x12. It helps to load your tires. I used water and automotive antifreeze. 1 gallon of antifreeze per tire, the balance water. Worried a little about freezing but has never been a problem under any temps and the antifreeze seems to save the rims from corrosion.
