Briggs electric starter problems?
george
03-26-2002 18:23:59
what causes these starters to drag & hang up on the flywheel?brushes good,bushings feel tight,rear cap not cracked,runs great without load.i have numerous riders with the same problem(14hp).
bronc13
04-14-2002 18:45:56
 Re: briggs electric starter problems? in reply to george, 03-26-2002 18:23:59
i have a briggs starter of a 10 horse and my problem is that once in a great while it works as should but any other time it engages by itself and wont stop unless you unhook the battery and then when try to do the same or rewind the starter piece by hand and then hook the battery back up it engages on its own again. anything would help im lost out here this my first year working on these briggs and starting to wonder why.
nick
04-07-2002 07:45:04
I've got a 16hp which won't engage; is there a solenoid ? how do I get it to go ?
ideas, please
Nick
mike
03-30-2002 14:25:55
I have a 12hp B and S which on starting will not engage on the flywheel, is this the same problem? I have tried everything but the only thing that seems to work is WD40, although I think they are supposed to run dry. Please let me know if you find the right answer.
mike
Fish
03-26-2002 19:57:55
It is a common problem with the OHVs. Check the
valve clearence and the rocker arm studs for
looseness. Fish
WCaviness
10-13-2002 19:22:31
 Re: Re: briggs electric starter problems? in reply to Fish, 03-26-2002 19:57:55
x
