12.5 HP Briggs Vertical Shaft Crank Journal Diameter
Dan
04-04-2002 18:13:41
I had rod break and stock crank journal needs to be ground to .020 undersize for the new rod. Machine shop doesn't have specs on stock journal diameter to know what diameter to grind. Can anyone tell me either the stock crank-to-rod journal diameter, or the diameter it should be for a .020 undersized rod. Alternately, please provide recommended crank-to-rod clearance and I can measure inside dia of rod and subtract the clearance to get the final crank diameter needed.
Thanks
Dan
04-04-2002 18:15:19
 Re: 12.5 HP Briggs Vertical Shaft Crank Journal Diameter in reply to Dan, 04-04-2002 18:13:41
Sorry...I should have posted model number.
engine is model 289707, type 0168-01
thx
lucs
04-05-2002 05:41:27
 Re: Re: 12.5 HP Briggs Vertical Shaft Crank Journal Diameter in reply to Dan, 04-04-2002 18:15:19
i like to have the rod in my hand when grinding a briggs crank,,,.0015 should be proper clearance...lucas
