Dynamark deck
dave
04-06-2002 10:24:45
Could anyone help me understand why the deck level lever, with a new cable, will not keep the front end elevated after selecting the desired height? Many thanks for any help!!!!!
Dave
Wally Rightman
04-20-2003 08:16:30
 Re: dynamark deck in reply to dave, 04-06-2002 10:24:45
I have a 1136 dynamark can anyone tell me the deck belt length, My rider has a remount bagger attachment.
tim fazzini
04-24-2003 11:07:52
 Re: Re: dynamark deck in reply to Wally Rightman, 04-20-2003 08:16:30
i have a dynamark1136 rear discharge need to know how to hook front of mower deck up someone gave it to me maybe a service manual
Bus Driver
04-07-2002 10:22:27
The old Dynamark literature that I have specifies that the front of the deck is intended to be lower than the back. One theory that I have heard is that this reduces the drag on the blades as the blades do not contact the grass when at the rear of their rotation. I think about 1/4" lower for the front should work well.
todd mosey
05-08-2004 11:56:14
 Re: Re: dynamark deck in reply to Bus Driver, 04-07-2002 10:22:27
bus driver, let me know if i could purchase a copy of that 1136 owners manual from you. murray has been no help on this. thanks> toddmo@qix.net
Joe in Pa
05-04-2003 19:10:06
Bus Driver, Do you happen to know the part# for the deck spindle on a dynamark 1136?
Lee Ehredt
04-07-2002 20:27:31
Hey! BusDriver, tell where I can find Dynamark lawn tractor manuals. Thanks a lot.
Bus Driver
04-08-2002 04:55:30
 Re: Re: Re: dynamark deck in reply to Lee Ehredt, 04-07-2002 20:27:31
My Father bought a Dynamark new about 1985. Model 1136 if I remember correctly. He died 1991. I was never able to find any literature for it. Mother died January 2002 and I have since found the original owner's manual. I think Noma now owns the name Dynamark-perhaps contacting Noma would help. Every time I spot a junked Dynamark, I ask about the literature-no one has ever been able to find their paperwork for the junked unit.
darrell
06-15-2004 02:08:05
 Re: Re: Re: Re: dynamark deck in reply to Bus Driver, 04-08-2002 04:55:30
hi.. i have bought a 1136 model 5288-4000 code 9054 and i am interested to see if you could email me a link to where i could find the manual or if yours is the same model could you make a copy of it and email it to me or send me a copy.. send me an email and i'll give you address if you can.. thx.. much appreciatoin for any help..
Peg
05-21-2003 14:14:04
You seem to have very helpful info. I have a 12hp Dynamark w/ 38" deck that I've been trying to limp along. My deck has 2 springs. The smaller one fastens to the cable used to engage the blades. The larger appears to apply pressure for the pulley brake. My problem is that I can't get the right tension and may have the spring(s) installed wrong. I've tried a variety of different ways with no luck. Could you show photo or diagram of proper installation of springs?
Lee Ehredt
04-27-2002 20:36:26
Bus Driver...thanks for your response. Will look for Noma. Thanks again.
Bus Driver
04-09-2002 05:01:00
The model is 3611-1500. Certainly not the best mower I ever saw. Only 3 speeds forward, very limited deck height adjustment, steering allows for only very gradual turns. Engine access is difficult due to the hood being bolted in place.
Butch Weisner
04-06-2002 23:02:58
Is the cable installed correctly? Did you do a front to rear adjustment on the deck when you install the cable? Later Butch
