265 dying
Handsome Jim
04-07-2002 07:58:48
Yesterday mowing the lawn for the first time, After mowing for about an hour my 265 started spitting and sputtering and died in fairly thin grass. After we let it sit for a few minutes, it started back up and ran fine and we were able to finish. It did the same thing last fall the last time I mowed but I think I ran out of gas then and replaced the fuel filter and it seemed to run fine then. I'm thinking I may have an ignition problem but I really don't know where to start.HJ
Handsome Jim
04-07-2002 15:06:34
 Re: 265 dying in reply to Handsome Jim, 04-07-2002 07:58:48
I probably should be a little more specific. It's a JD 265 with a Kawasaki engine. and so far it's only done it after running for an hour or more.HJ
MOWMAN
04-08-2002 14:59:32
 Re: Re: 265 dying in reply to Handsome Jim, 04-07-2002 15:06:34
IF IT WONT RESTART UNTIL ITS COOL THE IGNITER IS PROBABLY GOING BAD J.D. HAD PROBLEM WITH THESE, OTHER PSSIBILITY IS THE VALVES ARE STARTING TO GO GETS HOT SHUTS DOWN -GETS HOT CHECK TYHE OIL CHECK FOR MOUSE NEST UNDER THE ENGINE SHROUD AND FINALY THE FLY WHEEL KEY COULD BE SHEARED CAUSING A TIMING PROBLEM WHICH IS COMMON ON THAT MACHINE HOPE THIS HELPS, IF YOU FIND THE IGNITER TAKE AN OHM RAEDING IN BOTH DIRECTIONS THEN GET AHOLD OF DEALER THEY CAN TELLIFITS IN SPEC
doug
04-07-2002 09:40:07
it could be many things but do the obvious first check the points condition, second try adjusting the carb, one of these should cure your problem. hope this helps
