Briggs no spark
Tim
04-08-2002 23:35:16
I have a 6 hp Briggs vertical shaft that has no spark. The points/condenser were removed by the previous owner. Will an electronic ignition module work on this engine to replace the points/condenser.Model # 142702, type # 9124 01, serial #67051. 1967 Simplicity Broadmoor tractor.
Thanks.
SHANNON
04-17-2002 21:28:39
 Re: Briggs no spark in reply to Tim, 04-08-2002 23:35:16
MAGNETRON IGNITION I DEFINITELY GIVE IT AN A+++ EXCELLENT CHOICE!!!!
MOWMAN
04-09-2002 13:11:44
YES USE THE BRIGGS MAGNATRON BUILT INTO THE COIL ALREADY THEY DO HAVE A RETRO KIT TO UPDATE $16-18
Jim S.
04-09-2002 06:45:00
Yes, there are a number of electronic ignition kits out there that will work.
