Cub Cadet 1120/Kohler 12.5 HP
Tony Pitts
04-12-2002 18:14:37
Need some advice. The lawn tractor I bought last year that worked just fine when I parked it will not start. It is an older Cub Cadet 1120 (MTD years)with a 12.5 HP Kohler engine. I bought it from a trusted source last fall and it ran fine. I have only personally run it about an hour before it was parked for the winter. At first I figured it was just flooded. It will turn over and over and once in a while it was giving a massive backfire. I was giving the spark plug good cleanings with the torch, as well as clearing the gas out of the cylinder with it. It does have spark and I drained the old gas and put new in. What is really concerning me is that when I remove the spark plug, it is wet and black with what appears to be oil.
I have quit trying as it is starting to mike slight funny noises when it turns over.
I will probably take it to a small engine repair guy, but thought I'd see if you guys had any ideas. I'd rather save my experimental tinkering for engines I don't have to rely on.
Thanks,
Tony
SHANNON
04-17-2002 20:54:38
 Re: Cub Cadet 1120/Kohler 12.5 HP in reply to Tony Pitts, 04-12-2002 18:14:37
IF SITTING ALL WINTER IT MAY HAVE VALVE STICKING (CHECK COMPRESSION),THEN CHECK FOR CORRODED POINTS (IF EQUIPPED) OLDER ONES SHOULD.IF POINTS MAKE CONTACT JUST ONCE IN A WHILE THEN YOU HEAR-----KA-BANG----- AND YOUR EARDRUMS ARE RINGING.FUNNY NOISES ARE PROBABLY INDICATION FROM STARTER HAVING TO CRANK TOO LONG AND BURNING UP.THESE STARTERS ARE EXPENSIVE.INVESTIGATE PROBLEM BEFORE FRYING STARTER..... ...
