OK, so I went and picked up my parts tractor and now have a few questions.First off, I have the base of two decent tractor, so now I'm wondering which I should use. The first one which runs is a serial # 55280, the second non-running machine is in the 22000 range (sorry, didn't write it down). The second machine (the older one) has some issues, like the steering is shot, the dash and column is in pretty lousy shape. The thing is it also has lights, and it's set up with the "3 point hitch" (for lack of a better term). So what would you guys do, rob the 55280 to fix the 2200 (engine, steering, column/dash etc), or vise versa? Also, something that has me a bit confused it on the 22000 there's something extra installed, so bear with me as I try to explain in. if your sitting on the machine and look straight down there's a hole. On my 55280 you can see clear through, but on the 22000 the hole has been enlarged, and there's been something installed. It's looks like a leaver is supposed to be coming up through the hole, but it's been broke off. Looking underneath the machine I can see that there's a cast box that's looks like it's connected to the tranmitions. Any ideas what it is? Oh, and 22000 came with the mounting bracket for a Brawlo (sorry, something like that) plow, if that helps out at all. And just to add a little more fun to the pot, a friend know where there's another orig. cub, w/o engine that I might be able to get for free! Thanks, mk
