BS 17hp Intec with solenoid on fuel bowl
mike
04-15-2002 15:29:11
will this solenoid unsrew to allow draining of the fuel bowl? I would normally expect to find a brass metering jet in the bottom of the bowl, this solenoid needs to be powered to allow the thing to run. Before I try to take it out to drain the junk from the bowl, I'd like to know if there is something to be careful not to do. Ain't technology great. It's been sitting almost 2 years.
mike
04-16-2002 06:13:46
 Re: BS 17hp Intec with solenoid on fuel bowl in reply to mike, 04-15-2002 15:29:11
Many thanks. I posted my e-mail, but it didn't go through.
thanks again....Mike
Fish
04-15-2002 18:35:58
At the bottom of the bowl and the top of the solenoid there is a flat spot for a thin profile
wrench to grab, do not try to remove by twisting
the larger barrel portion, as damage to the unit
will likely occur. Fish
teej
04-15-2002 15:44:48
That solenoid has a tapered tip, which closes the main fuel nozzle when not powered. Prevents the engine from sucking gas into the cylinder when you turn off the key and it slwos to a stop. Supposed to help elminate the BANG that sometimes occurs after shutdown. You can remove it just like it was a bowl nut. Be caureful not to twist the wire too much as you unscrew it and break the wire off.
The little plunger in it should move easily as 12 volts is applied and removed.
