Engine stops when PTO engaged
Gene
04-15-2002 22:24:14
I have a JD 214 when I engage the electric clutch to engage the deck, the engine stops.
Jon
04-18-2002 13:18:20
 Re: Engine stops when PTO engaged in reply to Gene, 04-15-2002 22:24:14
There's a good chance the electric clutch is shorted out. :(
Marv
04-17-2002 20:28:17
Sounds like a saftey switch !
SHANNON
04-17-2002 20:13:40
SWITCH ON SEAT,IF PTO IS ON AND YOU HOP OFF SEAT ENGINE WILL STOP.
Steve from MO
04-17-2002 06:48:25
Mine does that once or twice a year. If you are lucky, it's just the belt for the deck that has got off track. So far, I haven't had to replace the electric clutch or any blade spindles.
In the deck manual there's a drawing of the proper installation of the belt. The belt routing isn't logical or easy to figure out without the drawing.
Scott Beckley
06-05-2003 12:30:42
 Re: Re: Engine stops when PTO engaged in reply to Steve from MO, 04-17-2002 06:48:25
If the tractor has a safety feature which shuts off the mower when you get off the seat, that switch may not be working properly and all you have to do is remove it. It should be located under the seat. However keep in mind that the mower blades will continue to turn when you get off of the mower so make certain that you turn off the PPO switch when getting off of the mower when it is running.
SamMI
04-16-2002 04:02:36
had the same problem with my F525 recently. turns out the PTO electric clutch was bad. HTH
