Briggs Stratton updraft carburetor
Denver
04-16-2002 18:13:52
This engine will not run from lack of gasoline. The carburetor is mounted on top of the gas tank. The gas suction tube has a screen on the bottom which I can not remove and the tube will not separate from the carb. Is there a check valve or something else in the suction tube? How can I clean the tube so gas will flow up through it? Thanks, Denver
ken
12-07-2002 08:04:49
 Re: Briggs Stratton updraft carburetor in reply to Denver, 04-16-2002 18:13:52
your carb is a pulsa-jet. it needs a new diaphragm and cleaning. it is underneath the cover on the side of the carb held on by 4 screws. watch for spring.
Alan
10-12-2003 18:56:56
 Re: Re: Briggs Stratton updraft carburetor in reply to ken, 12-07-2002 08:04:49
Hi
I have a 8hp, b&s engine with an updraft carby. I am looking for carburetor settings etc. The motor powers an old golf buggy which was running well.
The motor has a generator motor starter unit, it has good compression, plenty of spark, but will not fire regardless of what I have tried so far.
Any help would ba greatful.
Best Regards Alan.
